403 guys chime in
Ive got an Olds 403 out of a 1979 transAm, and am curious what can be done with it.
From what I have found online, Its got the same problem lots of engines from that smogger era have....low compression and small cam
But its got a huge Bore and a comparatively short stroke, so it should have some good potential
I have read that swapping Olds 350 heads on can bump the compression up, and obviously swapping to a less-dished piston would do so as well. If I swap on 350 heads, is it a must that I add larger intake valves to the heads?
But what I am really interested in is what can be done with this 403 WITHOUT those specific mods?
I mean how far can one go with a cam before losing low end because of the poor compression?
Assuming a mild camshaft was installed, how much might some head porting help?
Would an edelbrock 3711 intake help with more than just weight savings?
Is the engine such a dog without the headswap/piston compression bump that it just wouldnt be worth it to go thru it without doing them?
Would it be better (or maybe more cost effective) to just nitrous it 50 or 100 shot?
It needs a regasket at a minimum so I am considering this very basic build - tell me if there would be any benefit to it....
Edelbrock performer cam and intake
Headers
2.5" dual exhaust
TH350 w/ B&M kit, 1800 stall saturday night special torque converter
3.08 or 3.23 posi rear
The goal is to build/have a good reliable street engine that can break the tires free from a stop without brakes, and is sporty/responsive to the throttle. Would rev to, but not over, 5000rpm
So what can be done to wake this engine up? Any thoughts/opinions appreciated.
Headers
2.5" dual exhaust
