When rebuilding an Oldsmobile V8, is there a preferred oil pump brand? I have access to Mahle pump and pickup/screen, they are both made in the USA. Stock build/standard volume pump.
Also, are there any preferred oil pump driveshafts? I've read about other engines and how the shaft is an inherent weak point in the factory design. I have easier access to a Melling shaft as opposed to Mahle or Sealed Power. Was also looking at the Milodon shaft, but have concern with that not working in conjunction with stock parts.
