I am looking for a Oldsmobile Small Block V8 Turbo Set-up. Do they make one of these? And how much does one normally run if they do?
FE3X CLONE said:I also remember seeing a Karmanghia I believe at the Olds Powered nationals with a turbo and carb setup years and years ago. If I remember correctly that weird thing about its setup was that they moved the carb to the inlet side of the turbo so that it wasn't actually under pressure.
88hurstolds said:You are going to have to go custom on that, for my build I am going with custom exhaust since I will be pushing lots of CFM.
Some have simply turned around stock manifolds.
My thoughts exactly, turn around the factory manifolds towards the front of the car.
Markd03 (who's recently been taken into Gods hands) did a couple of these builds on ROP:
http://realoldspower.prophpbb.com/topic261.html
http://realoldspower.prophpbb.com/topic273.html
