Specs:
2007 TrailBlazer SS
AWD
3SS Option Pkg
ENGINE
Stock LS2 longblock
LS9 roller camshaft
PRC 1518 beehive springs w/seats and seals
LS7 roller lifters
5/16” 4130 chromoly pushrods (7.400” and .080” wall)
Holley EFI mid-rise intake (ported)
GM LS2 car throttle body (ported)
LS2 HD timing chain w/3-bolt sprocket
LS2 oil pump (ported and shimmed)
Custom gated oil pan baffle
CAT SFI flexplate w/ARP bolts
ARP crank bolt
Custom oil catch can
TPD engine mounts
POWER ADDER
House of Boost supercharger bracket (V1)
Procharger D1SC supercharger (polished) w/3.85” pulley
3.5" inlet pipe
12" AEM Dryflow cone air filter w/4" inlet
Procharger bypass valve
VS Racing 44mm wastegate
23x12x3 intercooler w/custom 3"/4” aluminum charge pipes
T-bolt hose clamps & heavy duty silicone couplers
IGNITION SYSTEM
8.5mm MSD SuperConductor sparkplug wires
Summit Racing heat socks
Stock ignition coils
NGK TR6 spark plugs
FUEL SYSTEM
52pph Bosch injectors (Ford GT500 spec)
Holley EFI rails
Braided fuel lines and fittings (-6 AN)
Pace Performance FlexFuel sensor kit (PAC-13577429)
OGS Propain injection system (propane)
EXHAUST
XS Power 1-7/8” S/S tubular headers w/catted Y-pipe
ARP header bolts
3" custom S/S dual exhaust system w/Magnaflow muffler
QTP electric cut-out
ENGINE MANAGEMENT
HP Tuners custom 2 Bar OS
Motorsports Innovations 100psi fuel pressure transducer (WB-762) w/-6AN adapter
GM
Grand National 2 Bar MAP sensor
Innovate MTX-L wideband oxygen sensor
Spectre 4” MAF housing w/Saxon PC screen
LS7 MAF sensor
TRANSMISSION
RPM Transmissions Level V 4L70E (
http://www.rpmtransmission.mobi/page27.html)
Yank Truck Thruster 2600 torque converter
AMSOIL ATL transmission fluid
B&M transmission cooler w/-6AN lines and fittings
REAREND & DRIVELINE
Custom aluminum 4" driveshaft
HD Spicer 1350 yoke
HD Spicer solid U-joints
SUSPENSION & BRAKES
Front
Prothane control arm bushings
Prothane swaybar bushings
MOOG Problem Solver ball joints, endlinks, inner/outer tierods
Bilstein shocks
Power Stop calipers (red powdercoated)
Power Stop drilled and slotted rotors
Clarksville Fastener S/S brake lines
ARP long wheel studs
Rear
Bilstein HD shocks (46mm)
Belltech 1.125” swaybar
MOOG Problem Solver endlinks
WHEELS & TIRES
Black Factory and Factory Reproduction wheels
Front: 20x8 w/275/55R20 Nitto NT420
1” billet wheel spacer
Rear: 20x10 w/305/50R20 Nitto NT420
0.5” billet wheel spacer
HD lug nuts
ARP 3.25" long wheel studs
BODY & CHASSIS
HOB windshield washer bottle relocation kit
INTERIOR
Autometer column gauge pod
Autometer SportComp boost gauge
WeatherTech floor mats
ELECTRICAL
Kenne Bell Boost-A-Pump
COOLING
LS1 dual electric fans
PCM of NC 3 relay electric fan harness
PCM of NC 160* thermostat
