im having a problem with my 84 regal , i changed the window motor, all new wiring and its still not working , ive tested it and i got power to both the switch and the motor. drivers side works fine?
clean the metal where the regulator assy mounts to the door, also the black wire that grounds to the door panel... sounds like you've developed a grounding issue...
