Ok I may get laughed at for this question but I need some help with the PCV system on my 231 3.8L v6 1984 cutlass supreme.
Number one and most important is the pcv valve grommet has fallen into the hole when i was trying to remove it. How bad is that? Probably pretty bad i assume. Do i need to take of the intake manifold and get it out?
Number two is the placement of the components. I mistakenly put the pcv valve in the wrong spot. I have 2 holes and i finally found the old pcv valve ( i thought it was just missing ). One hole on the outside edge of the engine on the passengers side and one right behind the carburetor on the passenger side. Which one does the pcv valve go into? I believe it goes on the one closest to carburetor right? If so then the other hole is for the breather???? Out of the breather hole the only thing that should be there is a grommet with the elbow in it and a hose leading to the breather element that goes into the air cleaner assembly right? Am i correct or way off?
Thank you in advance for all your help!
