Nothing wrong with a 350. All Pontiac boards will advise you to dump the "boat anchor" and drop a 455 in it. I dissagree. A 350 HO was offered fron the factory with better cam, big valve heads, etc, and it was potent. The Crane 262 cam that was a pussycat in a 400 was a wild child in the 350. Same stroke as a 326, 389, and 400, so torque peak is the same. If it's an earlier model with high compression, lots of 400 heads available that will give you bigger vaves and lower compression for today's cat-p gas. Any Pontiac 4 barrel manifold 65' and up will bolt on, as will RamAir exhaust manifolds or headers. Almost every 70's Firebird produced came with a 350 and they weigh about the same as an 80's GP. If the emissions and mileage issues weren't a factor, 350's would have been in those as well.
