Hello all. I'm pretty excited, as I finally have been able to find a Pontiac 455 for sale in my area. However, I have a few questions. The seller says the engine is a 1971, YC 529126 or YG 529126 (I could not find the 529126 number researching..), engine code is: 485428. The date code by the distributor is: E 18 4. The heads that are on the engine now (stock) are the D-98-18 (I will possibly be purchasing 6x heads from this guy as well, but do not have any info on them yet..).
So far, I'v been able to conduct that the engine is in fact a 1971 455 2 main that was backed behind an automatic transmission (Y code specifies this), and came out of a B-body car, aka fullsized car. The YC code put's the engine at being a 4 barrel engine rated at 325hp, but the YG code lists the engine as being a 2 barrel engine rated at 280hp. The heads are "D" port heads with 2.11 intake valves and 1.77 exhaust valves. CC's of the heads are listed as 111 and HP is rated at 280hp. So, I'm deducting that the engine was originally a 2 barrel carb, which would put the code at a YG engine, not a YC engine. These heads seem pretty good for stock heads, though with the 111 cc chambers, compression is going to be down. The date put's the car at May 18, but I'm not sure of the meaning of the "4" in the code is. Probably something simple as date that I'm over looking..
Anyway, any Pontiac gurus able to help me out here with what I will be buying? I'm not sure if my deducting and research is 100% accurate, but does any of it sound about right? I don't plan to go huge with the modifications to the engine, just a rebuild, intake, 4 barrel carb, cam swap, and springs upgrade to allow more cam lift for now. I thought it was decent enough to snatch it up at only $350.. Thanks guys! 8)
