Pontiac post '77 block question
G-Body_Vet
2,937
81
48
Anyone know if the post '77 350 & 400 blocks will fit our cars? I've read that they only used 3 mount bosses instead of 5. After I know whether or not it does, I'll make sure it's not a 557 block too. I came across a 400 out of a '78 TA pretty cheap and I'm thinking about grabbing it
It will fit but will be a 557. I wouldn't be concerned about the 557 for anything other than if you were building a race motor out of it.
Any Pontiac v8 will fit, from a 301 to a 455 and everything in between.
but use the 301 engine mounts.
I have the 301 mounts and brackets already for my 455 that I'm putting together. I'm still fairly new to Pontiacs and thought I recall reading something about certain blocks not fitting without fabbed mounts??????? I really want to have the car drivable this summer but realistically I'm a long ways away from finishing the build. I'd like to throw a 350 or 400 in it for the time being.
As for the 557 block goes, maybe I'm taking the PY forum stuff too serious. I was reading a thread over there and a lot of the guys seem to avoid them like the plague if they can help it. From what I gather they're prone to cracking and dropping the main cap dowels in the pan, whether stock or built.
I'm all ears if you guys have other opinions.
I have built several of these late block with that casting numer, all of them were around 350-450 horsepower and have never had a failure. There was a small write up in High Performance Pontiac about this subject and it says that these blocks are at a disadvantage in an all out race build but are ok at moderate performance levels. The stock 301 frame mounts and block brackets will work just fine, ive used them in a few g bodies with pontiac engines without issue.
What is a 557 block? The 5 mounting holes were to cover both the pre-70' models that only had 2 mount holes, and the 70'+ models that had 3 holes, so service replacement blocks would fit all cars. By 76' or so they had few calls for 70'+ blocks going into pre-70' cars, so the other 2 holes were dropped. It probably saved $.06 on each block. This was told to me by an old-timey Pontiac parts guy. The only time you need adapter brackets is when a 2 bolt hole block is used with 3 hole mounts, and vise-versa. Even then they are cheap and even can be fabbed at home.
Thanks for clearing that up about the mount bosses.
I borrowed this from http://www.angelfire.com/fl4/pontiacdude428/block.html
"400 Blocks produced after 1975 with the last 3 numbers #557 have an undercut support area from the main to the pan rail & I don't recommend for 400hp plus builds."
Here's a few threads about that block too.
http://forums.performanceyears.com/foru ... p?t=663490
http://forums.performanceyears.com/foru ... hlight=557
Man, that's news to me. Thank's for that info and links,I guess it was never as issue since most guys built the "good" blocks from the 60's early 70's. I probably have one of them in my 77' TA, original motor. So far so good but it's a very mild set up. This guy's motor is toast!
Definitely fragged for sure! If I came across one for a good price I'd run one myself since it wouldn't be getting built. I'm still hoping to find a dirt cheap 350 to play with for the hell of it.
