civic type cars pull .75-.85 g's in real life driving. Our boats can pull the same g forces with a little work (and only a few hundred bucks)
- tighten up the front of the frame, use all the bracing possible (check the f41 sticky for braces). Add the fatest front roll bar possible - it could be worth the investment to have a thicker bar made than is available in the aftermarket
- lighten the rear, don't box the frame in on the rear (this is different of course if you're going to take this car to a drag strip). Use the stock rear stabilizer bar or have a smaller one made (nothing less than .5")
- buy the lightest wheels and fatest tires that'll fit --- tires are the most important for turning corners --- . Low profile ones are dumb - you need some sidewall for cornering. 50 series are good. Get the widest ones that'll fit - 245's should fit with a little effort. 255's require a lot of work to fit in the front. if you put larger rear tires than front youre adding more grip (more cornering force) to the outside rear tire- remember these cars have too much grip on the outside rear in a turn in the first place, so get the same size all around (also for rotating reasons).
- steering box
- hard shocks
- alignment:
negative camber(allows for the inside/cornering tire to have a bigger contact patch to the road)
positive caster (front top spindle tilts rearward), a similar effect of more negative camber in a roll
slight toe out (unless you do a lot of highway miles)
it is possible to adjust bump steer to incline to toe out for more handling when the suspension is rebounding, but that's a little more involved
check with your local tire shop/mechanic on what they recommend for these settings, usually less than 2-3 for the first two measurements, and less than .5" toe.
- coils: The previous post had a good write up on springs. I'd have to add coils only complement all the other pieces of the cornering formula. With a real stiff coil you'll have a quicker rebound and more response, but energy is lost when the coils are too stiff. You should do fine with stock coils by just cutting them a half or full coil, see if a full coil is low enough for your desired ride height (if not you need stiffer coils). It just depends on your driving style, do you like the front end to have real aggressive response, or do you like to have a decent ride without jarring your skeleton. (I prefer the aggressive coil) Note steering response is not the same as steering ability
- bushings, nice new urethane ones - keep these oiled! or they'll end up like the average rubber bushing after a couple years.
- you tighten up the front enough, don't worry about weight bias, it's b.s. for an average street driven car
- coil overs are not needed, but they'll give an edge on a car that really needs to turn. The more vertical the spring is to the direction the car is moving, the more effective. Problem here is you see minimal gains if the shock is within 30 degrees of being perpindicular to the cars travel. So it's basically more b.s.
A lot of people talk about these car's steering geometry being bad. That's the beauty of double a arms is you can change that geometry, it's the whole point around having double a arms. The exact 4 link and suspension up front in g bodies have been proven to pull 1G in a track setting (this is different than a skidpad where understeering cars usually have higher numbers i.e. civics). All you have to do is add the right pieces and adjust them properly and you've got a helluva performing machine
