Hey everybody, I recently bought a 1985 Pontiac Grand Prix, with the V8... The previous owner stated that it needed a new prom chip, I've had it checked at the local GM dealership to confirm the issue & it is indeed the prom chip, problem is, I can't seem to find one for it, I tried Hypertech but they don't make a chip specifically for that year model car, also have went to Autozone & they can get a stock replacement chip, which is what I need & want, but their vendor, CardOne, is saying that there are four letters & numbers on the chip & that number is needed to order the correct replacement, problem is, when I look on the stock chip, there is no such sequence, there is only a Malaysia 980 with the Delco stamp under it with some numbers which I can barely see due to the plastic tabs holding it in place, then at the bottom of the chip, there is a sequence 8518AF 34023, it also has the letters CPN stamped on it that Hypertech needed as a reference, but when told those letters they had nothing in their system that could be used..... If someone out there has had the same issue or has any information on where to go to get this chip it would be greatly appreciated.
