Puddle lights / ghost shadow lights
ibgreezy
15
Has anybody installed puddle lights on their gbody? I have an 86 Monte Carlo ss. Thanks
Yes I have. Here is my puddle lights with underglow on and without...
That looks great! Did u install them in the bottom of the actual door or in the lower door panel? The only place I see on the lower door panel Is the angled area under the arm rest. Thanks
I was after a different affect so mine are actually mounted in the door mirrors. If you mounted them at the arm rest level you will lose part of your image, because it will hit the lower door panel. To mount it in our doors you will have to do some modifying of the lower door base.
