Okay. keep in mind I'm not an expert in any way building an engine. Anyway. lol. I started to assemble the top end of my 350 yesterday. Got the pushrods in it and started to tighten everything up. I used a factory length Comp Cams high energy pushrod. The problem i have is that there is way too much play on the rocker arms. its as if the pushrods are too short. Would not tourquing the heads all the way down maybe have anything to do with this? I have only tightened them as tight as I can without a torque wrench. But it just seems like there is way too much movement. 2 out of 8 valves are pretty tight. But the rest of the rockers are extremely loose. I did use a slightly larger than stock cam, but with a factory length pushrod wouldnt they be too tight and need a shorter pushrod? I know they make a length checker, but this is practically a stock mild rebuild. Need help!!!
