the trans crossmember will not bolt up. it seems as the 400 is abou 3 to 4 in longer...has anybody put one in and if so what crossmember did hyou use.
Blake442 said:You're gonna need to shorten your driveshaft too...
Or nab one from a car with a TH-200-4RBlake442 said:You're gonna need to shorten your driveshaft too...
88hurstolds said:Or nab one from a car with a TH-200-4RBlake442 said:You're gonna need to shorten your driveshaft too...
joe_padavano said:88hurstolds said:Or nab one from a car with a TH-200-4RBlake442 said:You're gonna need to shorten your driveshaft too...
Depends on what tailhousing length is on that TH400. If it has a short tailhousing, you can use the 200-4R driveshaft. If it's one of the longer tailhousings you'll need a custom driveshaft. In any case, the front yoke needs to be changed since the TH400 uses a larger one.
Blake442 said:With the short tail, you'll still need to shorten the driveshaft. The 200-4R & TH400 use the same crossmember, but the case for the TH400 is about 1/2" longer.
