putting an edelbrock on a stock 307
mkiiisupra said:
i believe edelbrock does make an egr carb. It will require an adapter/spacer iirc. Someone else might have some more information than I do.
On a 307 the EGR has nothing to do with the carb. The more important question is, are you currently running the CCC system or not? If you are, switching to a non-computer carb will require you to change the distributor, converter lockup, and possibly the A/C clutch wiring (depending on the year of the car).
