I'm going from bench to buckets in my 81 Malibu wagon I found a 83 cutlass wagon in the yard with a split bench can I use the tracks off that wagon and take a spot weld cutter and remove the brackets. Just making sure that it'll work last time I put buckets in I used washers didn't work the way I wanted was perfect you know. So I appreciate any help here's a pick of the one in the yard
