Putting the Super back in a Super Sport. 85 Monte SS
Bricktop
20
Hey guys, Here's my lil streetcar Iv'e been working on.
Bringing the roller home.
Solid car, No rust or rot. Re paint has failing clear coat.
All Aluminum LC9 5.3
turbo manifolds made from stock truck mannis
Circle D Billet Converter
Air to water Intercooler and Ice Box
5.3 going in
5.3 in its new home
Fox Mustang 8.8 vs. Stock 7.5 junk.
Upper control arm brackets for adjustable Instant center.
8.8 Installed with Viking double adj shocks, BMR extreme drag roll bar
E85 needs big pumps
Pretty much where I'm at now. 5.3 with twin T70 turbos, Z06 heads, custom cam on E85. I'm looking for 900 wheel hp.
Pretty much bolt in. I used the Trick Chassis uppers and boxes, 1350 u joint yoke and wheels with an inch more backspace than normal. The fox rear is a little wider.
gonna be a screamer. how did you rout the exhust from the turbos? is it going to the back of the car?
Thank ya.
The downpipes run above the a-arm, down between the tire and frame, then back under the car. Its tight by the tire and wouldn't work with anything other than 15x3's. I have around 1/4 between the frame, 1/4 to the tire at full lock.
