Quadrajet choke pull-off
Wageslave
1,791
3,417
As the snow has cleared and I am starting to get back into the Bonneville again, I am noticing that my choke isn't fully pulling off. I had rotated my electric choke coil cap all the way to where it wouldn't even engage the choke and it still would not fully release until i manually moved the counterweight. In the short term I added a magnet onto that counterweight to give it more weight and that seems to be working ok. I did check the vacuum pulloff dashpot and it is working fine and all the linkages to it seem to be free.
What is the best method to set the choke up on an assumed good non-CCC quadrajet?
Is everything clean? Sometimes they can get a bit goo'd up and stick. Does it release with a blip of the throttle when warmed up?
This COULD be helpful...from the 86 Monte CSM.
On a cold engine, loosen the three screws on the choke perimeter. Move the choke plate to where its edge just kisses the metal of the air horn. Tighten the perimeter screws.
Apply vacuum to pull off with the mityvac and see if choke opens about 1/16 to 1/8 inch. If not, use the adjustment screw to set the opening about 1/16th inch.
Reset everything and car should start and maintain idle.
I'll give that setup a try. I tried setting it hot to where the choke blade is vertical, but I may not have sufficient choke when it is real cold that way.
Reactions: 78Delta88
Some carbs chokes may end up being 2 to 3 times wider gap wise then others considering temp average and jets leakage mixture ect...setting in colder Temps should be best....it us possible to add lib a bit when you have enough experience...I have mentioned that back in the day I ran carbs with a small peice of wire or tin attached to the filter bolt that scotched the choke plate open in such a way but not be in danger of coming loose and getting into the engine I thought this worked out the same as the pullout fears aside " of course one can adjust something if it is in working condition
As stated, it has to be absolutely cold to set it. Loosen the screws, hold throttle open, and turn the coil cover so the choke flap is totally closed. Tighten the screws. Test the pull-off with a Mighty-Vac or other vacuum source. I like to start at 1/8 to 1/4 flap opening. Start engine. If it stalls, too much air, close the flap a bit. If it runs rough, not enough air, open the flap a bit. Use the screw on the pull-off to adjust. Do this until it works perfectly. The problem is waiting for it to be cold each time.
Remember the choke has to do three things right: On a cold engine, one tap of the gas pedal should close it completely. When the engine starts, it opens just enough to run smoothly. Then once the engine is hot, it opens completely. I have seen electric choke coils that were slightly out of kilter but still worked fine. By that I mean the hash marks on the coil housing did not correspond to the choke position. Even brand new ones. As long as it closes and opens correctly, don't worry about the hash marks.
On many CCC Qjets the choke coils have an anti tampering tab to locate and lock it to the factory position. The choke coils can't be rotated for custom settings unless you grind the lock tab off.
Finally got everything adjusted correctly and it is now working. I may still get another electric choke coil cap, as the one in it now is from a knockoff Rochester 2GC and doesn't have reference marks on it but that can be a challenge for another day.
