I have a Racetronix hotwire kit that installed with my old swap and I'm mating it to the PSI conversion harness. I need to ID which wires on the Racetronix harness go where? Any help is appreciated!
I have 4 wires coming from the Racetronix harness:
Wire 1 Grey
Wire 2 Purple
Wire 3 Red (10 gauge fused originally running to the alternator)
Wire 4 Black
This is the Racetronix kit
Per instructions from PSI You can activate the Racetronix relay with the PSI fuel pump relay, that is computer controlled. Following the diagram, the wire in pos. 87 will be 12 volts when the PSI relay is active. Install that wire to the race tronix relay to the 12 activation signal.
Wire 1 Grey
Wire 2 Purple
Wire 4 Black
