LSCustoms said:
have you found some and if so what year, i put the 2002 camaro brakes on mine, link in thread almost done, but if you have some eldorados i could research that too... what year
I bought brackets from scarebird for 85 eldorado rear disc i bought slotted rotors had to machine down the axles also got the rear calipers with intergrated parking brakes. I was wondering if i could use the porp. valve from CPP its a disc to disc valve with out using an adjustable one and can u use the park cable without modifying anything?
