Attached as some pics from a monte posi diff with 3.73 gears. How much rust is too much rust? The car is not a show car...Couple questions. 1.) How bad can a diff be rusted before the integrity of the unit is questionable? 2.) Will the guts of this rear fit in a 7.5" rear? I think this 88 Monte is a 7.625 in rear. If the ring gear and pinion and posi locker and everything else will fit into a 7.5 stock84-85 Olds Rear, I have other 7.5 that are not rusted. Just trying to keep things original. 3.) How often are axle bearings/carrier bearings needing replaced? I have no idea of mileage, but the teeth on the ring gear has virually no wear. I spun by hand and inspected visually and cannot find a reason to replace the axle bearings. Carrier bearings are not making any audible noise either. If the seals don't leak I don't plan on replacing those either. 4.) How thick are the axle tube walls? The brackets that hold the brake lines are completely rusted off and I'll need to tack weld on something to replace what is rusted off. Looking for some opinions. THanks.
