Rear window trim????
J.Rod22
216
9
Georgia
I have a 88 Cutlass Supreme Classic and I plan on removing my top, I found a 3 piece rear window trim from a monte in a junk yard but i know that i need a 5 piece trim for the cutlass. but my question is since i have the top piece and the two sides from the monte will those work if i find the two bottom pieces for the cutlass
Yes, but you'll have to trim the bottom of the vertical pieces since they go all the way down under the filler panel on Montes and need to be shorter to slip into the Cutlass-only lower trim.
Stripping the red paint off them would be a good idea too...
