Regal and Monte springs the same? (im new to g-bodys!)
muthstryker
46
Just seeing if i can put the monte springs onto my regal, there is a place that sells 2-3 inch drop springs for both front and rear and thought id check to see if they work befor buying them, i cant find any other place that has springs with that much drop.
well, all g-bodies have the same style and design suspension. the spring rates, shock valving and sway bar size will vary but parts fit from one to the other. one of the biggest things to check is what engine you have and what engine the springs are set up for (just v6 or SBC or BBC, displacement won't matter)
