regal dashes
TKITEZ
just wondering if dashes from later model regals are interchangeable?
(i own a '78 by the way)
thanks. 8)
The Dash for any G-Body from 78-88 should interchange.
The instrument panels do not, though.
the gauge clusters do interchange. my elco had the long sweep 85 mph speedo with a fuel gauge stock. after the new dash went in i replaced the cluster with a 115 mph speedo, tach, volts, h20 temp and oil press cluster out of an aero coupe parts car i had. all you need to do is get the schematic of the gauge cluster wiring harness of your old and new cluster and swap the pins in the harness. its very time consuming but very do-able.
Pre-82 Regal had the wiper controls on the dash, 82 and after had it on the left-hand stalk.
