I have to remove a cutlass dashboard to get the wireing harness for electric windows and locks so i can convert my car from manual to electric. How hard is it to remove the dashboard in a cutlass?
I dont have a 72 cutlass, I have a 78 but Ive taken the dash off probably 4 times already since the summer for various things but its really not that hard. There are about 40 screws and maybe 4 bolts or so holding it all in place. Make sure you remember where the screws came out. Its not bad. I found it way easier to do it if you pull the front seats out so you can lay on your back. I got the dash out and back in in a few hours and that was the first time Id taken a dash out of any car.
I found that the hardest part is getting back there behind the gauges to disconnect the wiring but its not terrible. Be patient, thats the key.
gottcha. 80's dash should be the same as mine. Like I said, Its pretty simple just keep track of the bolts and screws. There are a few I found a little tricky to find but remember to look under the front speaker cover, behind the wood inserts, and there should be a few bolts in the bottom corner.
