DelOhio said:I was under the impression that you had to cutt the shock mounts out to get bags in there. Soo for starters you'd have to replace the mounts and assembly up front.
Have fun
El Duez said:The front upper shock mounts are cut out with a hole saw and the rear spring pockets are also cut with a hole saw so those will need about a 1 7/8" circle welded in there. the battery rack should be welded to the frame so the trunk floor will have to be repaired.
