OK, quick rundown on what I did...
I replaced the oxygen sensor on the car. The old one was original, and I had heard of good boosts in performance and mileage by changing it. I got a new one from autozone, had the OEM style 1 wire connector on it and everything. I put it in, and drove the car a bit that night. Ran fine. The next afternoon I went to leave for work, and the car fired up, ran for a second normally, then started running really bad almost like it was running on 5 or 6 cylinders, then died out. I haven't been able to get it to fire and run normally since. The only way I can start it is if I floor it then it starts and chuffs out huge amounts of black smoke and stinks like gas like crazy. Still runs like crap till I let off the gas then it conks out. Is this somehow related to the replaced o2 sensor? I'm wondering if one of nylon teeth on the timing gear decided to give up the ghost and I jumped time somehow. It has 133k miles on the original chain and gears.. Also was thinkin maybe its something carb related... It has new plugs/wires/and cap/rotor.
Any ideas? I'd like to get it running again just to putt around until I get around to dropping a 350 Olds in later this summer.
