I finally replaced the TPS in my GP yesterday, after it going bad about 3 or 4 months ago. It was reading a full 5 volts, telling the computer I was at WOT constantly. I was getting about 8 miles per gallon. Unfortunately, I couldn't get the damn plug completely off the adjusting screw to be able to adjust the new sensor properly. Spec is .48 volts at idle, and mine is reading .7 volts. I haven't had the chance to adjust anything else on the carb yet. The issue I'm having is that when first started, the car will barely idle, without raising the RPMs slightly, or it will stall. Once it warms up fully, it will idle fine. Other than that, it runs and drives OK. Throttle response and general performance also seem to be a little worse. Everything seemed to come apart and go back together OK, although I did reuse the old air horn gasket. Just looking for a starting point on what to check or adjust. Thanks.
