replacing fuse box?
SilverShadow87
422
possible? i broke one of the prongs tryna fix the wiper problem... didnt know that was connected to the radio as well. as weird as it sounds, id rather have my radio work than the wipers right now, but i need this car to pass inspection soon and finally stop worrying about this... so is it possible to replace the whole box? cause i was told you cant just buy a new prong by itself.
im confused about prong. is this prong inside or outside of the car. have you got a photo? the fuse box not to bad to change out. you should be able to fix your problem with the fuse box you have in place.
like where the fuse blade slides into. i took the one out for the wiper and it was connected to the radio one too, so now i have no radio or wipers...
if Im understanding you correctly...
then a suggestion would be to just cut that wire from the fuse box, wire power to it with a separate inline fuse no need to replace the whole box for to fix that...
