That would be great.pics of it up and down. Do you have stock height spindles?
In these first pics, I still had the stock height G body spindles and factory front UCA's. (Sorry, I don't have any pics of it aired up as I was only taking the "glamour" shots at the time).
Since these pics, I've gone to the F body spindles (still stock spindle height) with the shorter Global West UCA's. That allowed me to run a much larger aftermarket big brake package (Wilwood 14" with 6 piston calipers).
Out back I'm using their "Cool Ride" setup with separate 'bags and shocks.
With factory front spindles and UCA's:
At full compression ("aired out").
The inner wheelwells were removed to check clearances.
At full extension (aired all the way up):
From underneath:
And now, with the F body spindles and Global West UCA's:
As you can see, there's not really much difference between the stock G body spindles, and the F body spindles. With this setup, I only have roughly 3/4" of ground clearance to my driver's side header. So for me, trying to go any lower with a drop spindle would be pointless IMO.
Hope this helps you out.
Donovan
