Royal purple is a very nice synthetic oil, better be for the better part of $8 a quart. The term better is quite a broad statement but in oil less friction = better.
Along with less friction comes less heat equaling more durability of parts, less wear, more gas milage, more hp, more tq. It just makes your engine happier.
As with any newer oil, oil change intervals are longer, given you don't have massive blow-by, to easily 5000-7500 even 10k miles or whatever you feel safe with.
A friends dad uses Amsoil (Big $$$) in his 02 Ford turbo-diesel and changes his filter every 7500 miles and oil every 15000. Mind you that's 22ish quarts at some $10 a quart.
And it's been proven that synthetics are far superior to petrol based oils for "slickness". They even had a segment on one of the Powerblock shows on it. They gained something like 8hp on a 400hp engine from just an oil change.
But to stop ranting and answer your question I think all good synthetics (Mobil 1, Redline, Royal Purple, Lucas) will give you similar results.
