S10 master cylinder swap
Sumariner
129
10
Aguy on facebook did a swap with the master cylinder below. He said it was a direct swap. Anyone here used this master cylinder??? I plan to swap mine this weekend!!!
I'll keep you posted
Update!!!!!! It's installed and the brake definitely feel much more solid than before. I'll test drive it later. Can't wait!
Reactions: pontiacgp
I also have drilled and slotted rotors with 2.75" piston calipers. Should brake like a champ now!!!
I checked out 18M974 on RockAuto. Does your Monte Carlo have metric fittings on the brake lines going up to the master cylinder?
Yes, My Monte has metric fittings
I'm not a fan of the gbody design. Mine was old anyhow.
