Hey Olds buds...Ive concluded that I have an issue with the accelerator cable on my engine being too long. Since I am using a 2bbl set up, and the car came with a dualjet on the v-6, my pedal hits the floor 1/2"-1" before the carb is WOT. I either need to get a shorter cable, reposition the bracket, or alter the cable length somehow. I know that because of the 2bbl, the cable attaches farther back on the carb than it would on a 4bbl set up with this engine. What I need to know is, what is the distance between the front of the intake and the cable attachment on a qjet set up on an sbo. This measurement will confirm for me that my cable length is too long, and will need replacement or modification. I have an older cable that came from a 70's cutlass with a 2bbl set up but I really dont want to swap the cable if I dont have to, and I have no simple way to measure the difference in length between the two cables. Im pretty sure that because of the lack of WOT, my tv cable is not in sync with the engine....any suggestions would be much appreciated! Thanks in advance....
Bill
Edit: After thinking about this some more....I realize that this measurement may not help me....but thanks anyway....
Bill
