serpentine setup
87ttop
344
39
chattanooga, tn
Does anyone have directions or a vid that could help me convert my stock 72 400 sbc to the serpentine setup I have the two big big aluminum brackets and a compressor, power steering pump. I need to get alternator and water pump. I am trying to get directions on how to take my stock stiff off and put the serpentine setup on
tc1959 said:
This what you need and the other picture is how it looks from the front.
tc wut does that ac delete kit run?.. seen a camaro late 80s early 90s @ the junk yard im thinking of getting the serp kit of of it
Do you have stock heads? I ask b/c I was unable to buy a serpentine setup with my stock 74 sbc heads due to the fact that on the passenger side head you need more accessory holes. Ole time stock heads had 3 holes on driver and 1 hole on passenger, newer styles have 3 on both. So you will either need aftermarket heads or newer chevy heads or do the unthinkable and drill and tap a hole in stock heads...I was warned by my motor shop that drilling and tapping was not a good idea.
kuruption109 said:
tc what does that ac delete kit run?.. seen a camaro late 80s early 90s @ the junk yard im thinking of getting the serp kit of of it
The kits are GM performance parts Summit has both with AC and without. they are spendy. If you can find a set up in a bone yard. Go for it ,I got mine from a guy on E-Bay. It was from a 92 Fireburd. He bead blasted all the parts and re painted and labeled every thing it looked like new stuff.
Also you need late model heads with the three holes.
