Finally got her running, all thanks to you all on the other posts.
I seriously thank you all for everything still a little odds and ends to do but over all shes running and staying running got her to idle.
Timing is all good.
Now just need new carb and exhaust and shes completely done.
Also one small problem, the car seems to not be engaging, like when I took her for a drive around the block when I would push the gas to get it going it didn't budge it felt like coasting even when I would push the gas to get it up and go.
Also the gas in the carb is flooding so it will shut it down when I push on the gas to mush, hence why I need a new carb.
But I got a sweet deal from a guy on the last post so I will be contacting him right after this is posted.
But again thank you all so much.
Here's some videos to show you all how she is now.
http://youtu.be/JzIVuaocPE8
http://youtu.be/GZ0Z4N3Iqj4
Here's the video of the carb, The gas is coming out of the bottom of the carb onto the intake.
http://youtu.be/q-JUS7NPPNc
Timing is all good.
