Shifter linkage doesn't fit transmission
CamaroAdam73
1,180
36
Hilton head island, SC / Wilmington, NC
My car is an 88 Monte carlo SS, originally had the 200R4.
I dropped my oldsmobile 403 / TH350 in and went to bolt the shifter linkage to the trans pan and only one of the holes lines up. Anybody else run into this?
When i say linkage the part i'm refering too can also be called range selector cable/shifter cable.
You may run into an issue using a 4 speed shifter on a 3 speed as well, might want to pick up a whole setup (shifter, cable, and bracket).
