Hi Guys.
I've been trying to determine which lowering springs to use front and back of my 87 el camino.
So far i've picked up from the "G body performance book" that Hotchkis 1902 are good for G Bodies. But my cruck has a 8.5 10 bolt rearend, and is also longer in the back than typical g bodies due to the pickup bed.
Also, i have removed all AC and changed heads and intake for aluminum ones, meaning front end is lighter than normal.
Can any of you guys recommend any springs that give a 2 inch drop front, and 1or2 inch drop back?
The hotchkis are expensive, and if the dont really lower the car, cutting springs is not possible in the back. Cutting them also kidda defeats the purpose of buying them. Some places obline vendors even write air bags are a must for the rear. Ugh!
I wont be hauling loads with it. An occasinal engine or transmission perhaps. But for that i could just swap in tve current air springs and pump them to 80psi!
Please advice me. Im going crazy in moog charts. I've been searching threads here abd there for 2 days without really shedding any light on the issue:/
Thanks in advance.
Tim
Thanks in advance.
Tim
