I just put the mufflers on the olds so I could start driving it around a little before we do the new crossmember and full exhaust.
It was running fine, but the timing was a little off, so i had the light and was trying to get it situated and next thing I know it won't run! this happened before, and it was a bad module. this time i figured it might be a bad coil beacuse i have a new module, so i put a new coil in it. that wasnt it... Its an HEI dist, and i got it from the junkyard. I had no problems with it when we fired up the motor for the first time, and for a while after that.
Getting a constant 12v to it, have new plugs, wires, cap, and rotor. Don't know whats going on here. Can it be frying moudles for some reason? Any ideas? It cranks over fine, have fuel, but no spark...
The reason why I say it also might be the carb is because I bought it used. its an E-brock 1406, worked fine for a while too. The car died on me another time after i put the new module in too, this time it had fuel AND spark, but it didn't want to start figured it might ave been the carb. let it sit for the night, and the next day it started right up.
I'm sick of all these stupid little things that keep going wrong, of course this happens the day before i was going to drive to my buddies house to put the new crossmember in.
