I have a nice 1978 only silver speedometer that I scored cheap. Now I found that it may be defective. If I insert a speedo cable and spin it with my fingers, the needle pegs. Other speedos I tested I can use a drill to spin the cable and the needle gets to a speed, then hovers there, like normal. This one seems to be unable to disengage at any speed. How do these things work? Is there some sort of viscous coupling inside? Can it get thick and stick? Is it purely mechanical? Is there a fix for this? I think the odometer is stuck too. The speedo on my Bonnewagon I was able to get inside and re-set it all to 00000. This one I can't move any of the dials. Can that cause the needle problem? I am sure the MPH and ODO are connected so maybe that issue is causing the other? I am stumped by this.
