Spoiler for 87 Cutlass Salon
You can also pick up one from a salvage yard off an early 90s firebird. Usually 20 to 50 bucks. If they don't have one they can often locate one with the computer. Be forewarned though it will require some fabrication to make the stands longer and putting together the hardware to mount it to your trunk.
Hey Vern, you should stop in sometime if you're back in the area.
You may want to point out that the ends taper to the rear on these spoilers and they're also not quite as wide as the H/O spoilers.
Thanks I will.
