Turning the key and hearing horrible noises. Started like this...
85' GP, *thought* I had it ready to drive today but forgot about this problem. It's an automatic with a 200-4R. I had a starter on there that worked great...but I dropped it off my work bench and the casing and solenoid cracked (???..yeah idk). I would've replaced it with the same thing but it had no markings on it what-so-ever. Now from what I understand, the 168 tooth flex is 14" and the 153 tooth one is 12.75 in. Mine is on the car so it's hard to measure, but about 1/3'd of the way up, the diameter is over 12", so I'm guessing I have the 14 in. one. The starter that worked also had a staggered bolt pattern.
The starter on there now makes all sorts of horrible grinding noises...doesn't engage right. Tried it with 0, 1 and 2 shims..no luck. I'm going to order a new one from summmit. Anyone have any similar experiences and can help me find what I need?
PS - It did manage to start once, and sounded/ran great, so i'm 99.9% sure this is related entirely to the starter.
Thanks in advance.
-Mike
Thanks in advance.
-Mike
