I was thinking of changing my power stearing to manual stearing I heard that an s10 box would work i wanted to know if that was true or not and what other boxes can i use :?: :?: :?:
Bonnewagon said:Any Saginaw manual box from the 60's on up will swap right in. Just be sure to get the correct Pitman arm. The manual and 600 series (snap ring cover) use a small diameter Pitman shaft. The 800 series (4 bolt cover) uses a larger diameter Pitman shaft. The rag joint changed too, but I forget what the year was.
