Okay. So I'm running an '85 Pontiac Grand Prix. It has the HO 305 from a Monte SS, and it's got the turbo-350 trans (three-speed).
A few months back, I noticed that the front passenger wheel was grinding. No problem there, wheel bearings. I also noted a little bit of play in the wheel, which I took to be the idler arm.
I replaced the idler arm. I was working a lot and didn't have time, so I took it to the shop to get the bearings replaced. The mechanic there (who owns an '87 442, ironically) replaced the bearings in both front wheels, replaced the rotors and did some brake work. I asked him to check the idler arm, just to double-check my work. He says the front end is tight.
For some reason, though, my steering seems a lot looser than it used to. I don't know if it's because something has changed, or if it's because I haven't driven the car in a while (having taken it off the road for about a month to deal with the bearings, and I was driving an '89 Jeep Cherokee), or what. It used to be very sensitive... to the point where the minute slope of the road made the wheel pull very slightly to the side. It still does that, but steering kind of feels more like I'm suggesting a direction to the car, and it decides where to go a second or two later.
It's tough to describe, and that's probably a terrible description, but... yeah.
Also, twice now, when I've come to a stop, I feel a... er... it's kind of like if I had a box of bowling balls in my trunk, and they shifted as I stopped. My first thought was that someone had very slightly tapped my car from behind, but when I looked, the closest car was like 20 feet back. I do not have a box of bowling balls, or anything of that sort, in my trunk. And I can't find anything that would cause it.
Any thoughts?
AJ
Any thoughts?
AJ
