will a steering column out of an 85 cutlass work in a 78 cutlass they are both tilt the 85 has cruise and the 78 does not
Can he swap the electricals from the 78 to the 85 column?Blake442 said:Probably not. While it will physically bolt in, there's a good chance that the wiring will be different since the '78-'81 cars have the wiper switch on the dash, and the '82-'88 cars have the wiper switch in the turn signal lever.
supercrackerbox said:The collapsable shaft that connects the steering column to the steering box is '78 specific. On my old '78 Regal, I swapped in a steering column from an '84 Monte Carlo, and had to get that shaft as well. Beyond that, it was plug and play- wiring included. The only differences will be if your car has cruise control, and if the wiper controls are on the signal stalk or on the dash.
joe_padavano said:There is another difference beyond just the wiring. Starting in the early 1980s, GM did away with an electric neutral safety switch and instead used a mechanical interlock in the steering column between the lock cylinder and the electrical ignition switch.
Blake442 said:joe_padavano said:There is another difference beyond just the wiring. Starting in the early 1980s, GM did away with an electric neutral safety switch and instead used a mechanical interlock in the steering column between the lock cylinder and the electrical ignition switch.
I thought all '78-'88 G-bodies featured the mechanical lock... :?
