i have a 355 sbc with a .489/.476 lift cam with a duration of 287/317 and comp cams suggest running the timing between 35-38 and im around 37 right now. I only have a 9.4 compression motor as well. I was suggested a "budget starter." Its a china made gear reduction starter made in china that i paid $60 for, but multiple people have said they have good luck with them. I had the starter tested and it only pulls 35 amps. im using the 3 stock ignition wires and a 6ga wire from the battery. I am also running a jegs starter heat wrap around my starter. Does anyone have any clue or suggestions as to why it wont start once its up to engine temp?
by hot i mean up to temp (190)
