Im trying to plan out my stereo system only problem is my car is a hour a way getting painted. Whats the biggest in cubic ft sub box that will fit in a 86 cutlass. The speakers I have are re audio *** 15s they call for 4 cubic ft each speaker. Whats the biggest box you have been able to fit. If I have to tske the whole trunk up and take the back seat off and fire them into the cabin thats fine.
You would probably have better luck fitting the box where the back seat is. I had a bright idea years ago of putting two 18's in the trunk of an 82 Monte Carlo and hated the size that the box had to be. It took up the entire trunk and left no room for amps, battery, etc.
But if you are set on having them in the trunk go check out SteveMeadeDesigns.com. Lots of info there.
It'd have to be over the fuel tank, not under the rear package tray. The box for my 1 12" just fits under the rear package tray. You'd prolly end up having to build the box in front of where the trunk floor raises up.
