Super Slow windows
hajnovak
126
5
scranton Pa
Driver and passenger side power windows are about as slow as they can get without stopping. I was just wondering if a motor swap will cure this or is it something else? Thanks Mark
yup...........had the same problem. i bought 2 new window motors and now they are fast and powerful. i think that will solve your problem.
heres a link tp pics that will help
photos/thumbnails.php?album=88
peace
Just some tips--
While changing the motors, clean the electrical connections from corrosion and dab a bit of electrical grease on the wire connections to help prevent potential future corrosion from causing issues.
Also, you MAY want to clean the terminals, or even replace the switches if you can, of the windows while you got it apart. Sometimes the switches go bad and corrosion builds up in there causing resistance.
And lube up the mechanicals of the window lift mechanism and inspect for damage, corrosion, etc. before putting it back together.
