It all depends on what you want from your swap. Do you just want the car to move under it's own power, or do you want the A/C, Cruise control, gauges, etc to all work? You can do it with just a simple engine/trans combo out of an old truck and get the car to run just fine. However, you should really change the front springs, radiator, exhaust, fuel line routing, some of the wiring, etc when doing this swap. It isn't a weekend job by any means unless you really butcher it. On my 1985 Cutlass, I did the same swap, and used a 1977 350 and a 1986 TH200 4R automatic. I changed: springs, radiator, mounts, trans x member, exhaust, alternator, starter, hoses, brackets, wiring harness, PS hose, distributor, fan shroud, fuel pump, fuel lines from tank to pump, trans dipstick, sway bars,plug wires, distributor, carburetor,belts, pulleys, steering box, body to frame mounts, rebuilt the front suspension with new joints and poly bushings etc. and did not have full functionality of all major systems right away. I botched the HVAC vacuum controls ( easy fix) , ran out of money and did not get the A/C hooked up, the used trans gave way 15k miles later, the 2.41 rear axle gears and .67 overdrive didn't like each other- a $50 3.23 geared rear solved that. It is an involved job and while it is do able by yourself, be sure you have a parts runner and enough space to do it before you start. My car was down for almost a month due to a comedy of errors that kept me from finishing it quickly-and the engine/trans were assembled to each other with all accessories, exhaust downpipe and a complete 85 305 G body wiring harness already attached to the engine before I started removing the old drivetrain.As far as satisfaction goes, I am very happy with my setup. It gives better fuel economy and driveability that the V6 did, and it has plenty enough power for my needs. My engine was built to maximize low to midrange torque and as such idles at 650-750 RPM. I estimate that the car would run mid to high 13's with enough traction, and with the last few pieces of the puzzle in place, should be capable of 17-18 MPG around town ( it gets 15-16mpg now with the wrong carb and no torque converter lockup). I would run different heads than I did if I built the engine today, but it is an overall satisfying engine for what I use it for.It also does not overheat, and runs around 185-195 when it is 95 degrees out with just a simple rebuilt waterpump , used clutch-type fan and a 3 core radiator out of a junkyard car ( it was almost new). I spent $4,000-5000 on the initial swap, but used a new engine and other parts rather than used ones. You can do it cheaper than I did by using a well chosen parts car.
