So here we go again with another cluster question
. I am in the process of installing a vintage air unit in my 1979 Monte. When I took the dash apart I found the previous owner had bascally destroyed the cluster while doing some "repair" work. I pulled a few clusters from a local salvage yard today to make 1 good one out of 3. Here is my issue-My cluster is a rally cluster. The cluster I am going to use is a idiot light cluster. I use mechanical gauges so I do not care about gauges vs idiot lights and I actually like the later cluster I am wanting to use with the clock delete better. Now I know the printed circuit boards are different between these two clusters but what all does this effect? If I hook the idiot light cluster up in my car without changing the pins on the connecter will my dash lights, signal lights and gas gauge still work properly? Or will I need to switch pins on the connector? Also could I possibly use one of the idiot lights to wire a shift light signal to?
