This is for a GM Borg Warner NON-WC T-5
Just in case anybody is looking for the bolt size on the T-5, "like I was", look no further.There METRIC and here they are,
Tail shaft(x8): M10-1.50x30
Input shaft bearing retainer(x4): M8-1.25x20
Top case cover(10): M6-1.00x20
I don't have the size for the shifter but I think there the same as the input shaft retainer,just a different length. Now
for the Case cover there are 10 bolts that hold it on but 2 of them are special so you might have to re-use those 2 and only buy 8 instead of the 10 I stated.
Also note that the tail shaft bolts have a head with a washer already built into them so if your not using a direct replacement bolt, you should uses washers with them.
Peace
Peace
